![]() | Home > Maintenance & Mods (L322) > Squeaky belt |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
Works for sweaty gonads too! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7864 ![]() ![]() ![]() |
I take it you have to strip most of the covers off to get the talc where it needs to go? 2011 Range Rover Vogue SE 4.4 TDV8
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Mine got so annoying that I had a new tensioner fitted but didn't cure it 100%
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
mjdronfield: nope, just turned the engine off, tapped a little talc in the gap & hey presto, sorted. Took the guy all of 2 minutes. Dare say if you're clever enough you could make yourself some sort of 'blow pipe' & get it right on the belt. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Brill. Been putting up with mine squeaking for nearly a year. Driving me bonkers.
mjdronfield: If you pop the top plastic engine cover off, there's room between the radiator & the engine to squeeze a hand down there, or "aim-squeeze-fire" the talc from above as it where. When he started the engine up there was a slight puff of talc & that was it, quick wipe round with a rag & all's still quiet.
