Home > Technical (L405) > Generally quiet but. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
Tyre pressures OK ?
14th Mar 2020 8:10pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
I drove for 45,000 miles on my original 21” rims on my very similar specced 405 and apart from its extreme tendency to tramline on motorway lorry ruts, I was quite happy with it. I bought a set of inexpensive 20” rims with the standard 255/55R20 tyres to use for winter wheels, but tried them with their standard M+S tyres and the car was transformed. The tramlining was gone, the ride made it feel like a different car and road surfaces and imperfections could be ignored. That was 36,000 miles ago and I’ve never looked back. |
14th Mar 2020 10:01pm |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 245 |
I noticed this with mine. Original set up was 22’ wheels with a 40 profile, swapped to 21’ with a 45 profile and noticeably better but still not perfect on poor surfaces. I’ve settled for that compromise at the moment as I like the style of the 21’ wheels and they do give an excellent ride on everything but really poor surfaces. |
14th Mar 2020 10:47pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
I think the ARC control module was updated for the 2016> cars, there is something in my mind about having 2 valves not 1 after a certain date. So I don’t think that’s it. Could be bushes on the ARC as I reckon that are under srain a lot.
15th Mar 2020 8:32am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
What about the front suspension update / TSB ?
15th Mar 2020 9:22am |
That I don’t know about?
15th Mar 2020 10:26am |
Checked the tyre pressures, were a high at the rear and about 38 at the front. So not too far out now set 34 front 37 rear. There is nothing that can't be fixed with a hammer😜😜
15th Mar 2020 10:27am |
I don't know too much but I think early 405's have had knocking / roughness addressed with new components. Hopefully an expert will elaborate. But search and you'll find info Mark.
15th Mar 2020 10:43am |
Ah, yes. I read about that. That’s the issue with the ARC control Module I think. Pretty sure mine should have the updated version.
15th Mar 2020 5:47pm |
I think it's more than electronics. I could be wrong though.
15th Mar 2020 6:20pm |
Yeah, its the valve block. There is nothing that can't be fixed with a hammer😜😜
15th Mar 2020 6:25pm |
Here found something:
Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
15th Mar 2020 6:48pm |
Also here which mentioned the valve block and also bushings etc
15th Mar 2020 6:51pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Northern...did you get this sorted then with the valve block replacement? Is it an easy DIY or is there fluid/compressed system? 2014 FF Autobiography 5.0 SC
16th Mar 2020 6:06pm |
