![]() | Home > Technical (L322) > Code Reader/tow bar electrics |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
No coding needed on a 2011. Buy the genuine 13pin kit and plug it in. Make sure the cross member grommet is fitted correctly. Use silicon spray. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Seancod Member Since: 08 Jun 2019 Location: Cornwall Posts: 20 ![]() ![]() |
Thanks for that, I presume the tow bar kit I looked at has an after market loom, that’s why it needs coding. |
Maybe, not sure. I just got a genuine one from site sponsor Duckworths. Plugged it in. Job done.
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Socket works a treat for topping up battery from charger as I do not use L322 often enough.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Sorry to hi jack a thread, but if i wanted to replace my existing towing electrics is this easy to do?
2012 Westminster.
Tow electrics can all be fitted with bumper in place. The trickiest bit is getting the grommet to seat properly. Use silicone spray to ease fitting. Small hands help |
What code readers do you guys have |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
IID Tool best one to have for a RR |
