![]() | Home > Technical (L322) > TD6 Glow plug dash light not illuminating |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7895 ![]() ![]() ![]() |
In all the years I had mine, I never saw it illuminate once. I did have starting issues ar one point, but that was 2 faulty injectors.
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
If it helps, my 53 TD6 shows the glow plug light and a message saying "Pre-heating" when starting on cold mornings. Stays for a few seconds. That said, when it starts it smokes like an old bus for the first few seconds. I've put this down to dud glow plugs but reading how they often like to shear off when removing them, I live with it. Only happens when the ambient temp is around 6 degrees or less. 2004 Vogue TD6 - Remapped |
ianr63 Member Since: 26 Oct 2017 Location: Cheltenham Posts: 13 ![]() ![]() ![]() |
Thank you SidewaysMatt that is helpful.
Thanks Ian, good to hear that glow plugs can come out cleanly! 2004 Vogue TD6 - Remapped |
