Home > Technical (L322) > TD6 Glow plug dash light not illuminating
ianr63
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
L322 TD6 53plate, Problem started with a Glow plug relay failure notification on IID tool after a a non start on a cold morning
I have replaced all 6 Glow Plugs with Delphi, replaced Glow Plug Relay, Checked Fuse behind battery.
With the multi meter power going to each heater plug top via the timed glow plug relay.
I still have no Glow plug illumination lamp working on Dash and Poor starting or non starting on a very cold morning, when running it drives well.
before all this happened starting was not an issue.
any ideas ?
Post #545648 1st Mar 2020 11:20am
mjdronfield
In all the years I had mine, I never saw it illuminate once. I did have starting issues ar one point, but that was 2 faulty injectors.
You might have a different issue if you have investigated the relay etc though.
More knowledgeable folk will be along soon....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #545655 1st Mar 2020 12:51pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
If it helps, my 53 TD6 shows the glow plug light and a message saying "Pre-heating" when starting on cold mornings. Stays for a few seconds. That said, when it starts it smokes like an old bus for the first few seconds. I've put this down to dud glow plugs but reading how they often like to shear off when removing them, I live with it. Only happens when the ambient temp is around 6 degrees or less. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #545774 2nd Mar 2020 12:53pm
ianr63
Thank you SidewaysMatt that is helpful.
again this morning 0 deg airfrost no bulb illumination engine cranks non start, charge up for 15 mins and booster pack this spins the engine fast enough for it to catch and run.
before the glow plug relay failure i had the same as you glow plug light illuminates for a few seconds crank the engine starts up smoking like a good old bus. i did manage to change all my glow plugs about 2 hrs work, need to run / drive until hot then take it apart plugs came out OK (i did a pre dismantle before just to make sure i could get to the glow plugs before they cooled) and no hidden seized bolts etc on the way, in my opinion worth doing.
i will update with any findings asap
Regards Ian
Post #545790 2nd Mar 2020 3:20pm
SidewaysMatt
Thanks Ian, good to hear that glow plugs can come out cleanly! 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #545880 3rd Mar 2020 12:53pm
