Home > Technical (L322) > Oil-pressure-sensor passes oil-pan?
flashgordon
Germany
Hello,
have you heard of or can you confirm that
a cable for an oil-pressure-sensor goes through the oil-pan?
This "design" would cause problems if this cable is only a little "damaged" over the years I
because this would lead to "short“
and in the long run oil could -- via capillary force -- rising up the cable and reach the control unit?
This question is related to the error message that I see when I start a fault-search with the IID-tool (the is no warning symbol or warning message on the Instrument Cluster)
Have a nice weekend
[/img]
Post #545442 28th Feb 2020 12:47pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Love that error code so easy to understand the problem.
Post #545443 28th Feb 2020 12:50pm
TomCobbly
No idea about the wire but that error sounds like an air leak to me! Question 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #545444 28th Feb 2020 12:54pm
Baltic Blue
The oil pressure sensor is no where near the sump according to the Workshop Manual.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #545447 28th Feb 2020 1:30pm
flashgordon
Germany
Thank you for your quick response.
I've made an LR-appointment for a "smoke test" end of next week to look for an air leak
Post #545453 28th Feb 2020 2:34pm
