![]() | Home > Maintenance & Mods (L322) > rear wheel arch protection |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Hi all
DAN@DUCKWORTHS |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Dragging up an old thread, I'm looking to use something like these to protect the inner arch lip inside the rear doors (packed with grease as many have done). However, I recall someone saying that the Freelander 2 trims are exactly the same but longer. The correct trims (part No.LR001623) are obviously ok for the rear section of wheel arch as they're made to fit here, but they aren't long enough for the front section. Have I remembered this correctly? And if so does anyone know the part Nos for the Freelander arch protectors please?
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
The LR001623 is part number for Freelander. There's not one made for L322. Ordered 2 but have not yet arrived to confirm how long they are. At the moment plan to use only for front part of the arch. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Got all my info to do the job on these 2 threads
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 184 ![]() ![]() ![]() |
My 2010 already has theses fitted |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
I did mine with these:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Bladders there's a kink in the lip the around 12 o clock position, does the door edge stuff adapt to the kink?
GGDR - i cut mine down in size so that the rubber strip only covers the front lip up to that change in the lip. From memory that's as far as the OEM strip goes too. Current: FF Westminster money pit
