Home > Maintenance & Mods (L322) > rear wheel arch protection
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hi all
Anybody tell me what part numbers needed for rear wheel arch protection trim?
Post #242168 12th Feb 2014 12:10pm
verydisco
LR001623 x2
Paid 7 euros HT a pop from Service 4x4 last week Thumbs Up
totain4x4.fr l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #242183 12th Feb 2014 12:51pm
DAN@DUCKWORTHS Thumbs Up
Post #242189 12th Feb 2014 1:14pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Dragging up an old thread, I'm looking to use something like these to protect the inner arch lip inside the rear doors (packed with grease as many have done). However, I recall someone saying that the Freelander 2 trims are exactly the same but longer. The correct trims (part No.LR001623) are obviously ok for the rear section of wheel arch as they're made to fit here, but they aren't long enough for the front section. Have I remembered this correctly? And if so does anyone know the part Nos for the Freelander arch protectors please?
Huge thanks. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #545418 28th Feb 2020 9:38am
322BLL
Estonia
The LR001623 is part number for Freelander. There's not one made for L322. Ordered 2 but have not yet arrived to confirm how long they are. At the moment plan to use only for front part of the arch.
Post #546416 8th Mar 2020 9:56am
DrRob
Got all my info to do the job on these 2 threads
https://www.fullfatrr.com/forum/topic9387....p;start=15
https://www.fullfatrr.com/forum/topic22530...bber+strip
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546418 8th Mar 2020 10:31am
darrenm
My 2010 already has theses fitted
Post #546545 9th Mar 2020 11:59am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I did mine with these:
https://www.ebay.co.uk/itm/Car-Door-Guard-...27cac56ea1
Filled with Bilt Hamber Dynax UC anti corrosion wax Thumbs Up
Takes a couple of days to dry then the beading is stuck on good and water tight. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #546574 9th Mar 2020 3:11pm
GGDR
Bladders there's a kink in the lip the around 12 o clock position, does the door edge stuff adapt to the kink?
I bought some rubber similar but the kink is too tight and I want one whole rubber without any join to run around the entire arch front to back.
. Cheers, Greg
Post #546633 9th Mar 2020 8:36pm
Bradders
GGDR - i cut mine down in size so that the rubber strip only covers the front lip up to that change in the lip. From memory that's as far as the OEM strip goes too. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #547132 14th Mar 2020 2:23pm
