Home > Technical (L405) > L405 3.0 TDv6 Crankshaft failure (rumours & facts) |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
I’ve just found this on the Jaguar F-Pace forum which may assist in understanding the issue. Not sure if this has been posted before, apologies if it has.
24th Feb 2020 9:17am |
I didn’t attach a link in my original post......but try this. The relevant section is near the bottom of page 1
24th Feb 2020 9:46am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Thanks Buz, but I meant the one in you latest post:
24th Feb 2020 10:39am |
Oops, didn’t spot that URL.
24th Feb 2020 11:41am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
If that were true, then the early 3.0 engines in the RRS/D4 would be fine. But, they are not, they still snap cranks... However, I do agree with short journeys not doing the car any favours |
24th Feb 2020 1:18pm |
Hi Mike,
24th Feb 2020 6:14pm |
I think it's a combination of issues, TBH |
24th Feb 2020 6:40pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
But the finding that a large number of engines are affected does not seem to be borne out in real life, at least so far as the Full Fat is concerned. |
24th Feb 2020 7:59pm |
An interesting thread found and posted today by Buz. The thread suggests preventative maintenance options. It does not cite any examples of L405 3.0 TDv6 crankshaft failure which is the point of this ffruk thread and the drum long term banged on this forum. Also worthy of note that the last entry on the thread highlighted by Buz was in 2016 and we are now in 2020 Based on sound research, well documented on this and linked threads, there is still nothing to worry about with the L405 TDv6, unless or until someone produces a shed load of stats of L405 owners being left high and dry following crankshaft failures... And if that was a fact, given the reach of this ffruk forum, would we not have heard by now? |
24th Feb 2020 8:04pm |
Bazz Member Since: 09 Dec 2024 Location: North Down Posts: 3 |
Hi all.
9th Dec 2024 1:47am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2495 |
Replace both the main and big-end bearings with heavier duty versions (eg Kings) for starters. |
9th Dec 2024 6:52am |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 135 |
Ford redesigned the crankshaft when they used this engine in their F150 truck, presumably because of the failures that had been seen in JLR vehicles. I am not sure if the cranks are interchangeable between the JLR TDV6 and the Ford Powerstroke unit. The engines are effectively the same in many of the main points so it is feasible that they are able to be swapped and a good place to start in researching a solution. |
9th Dec 2024 7:26am |
The improved crankshaft was reportedly fitted to the LR engines too. Both the F150 engines and the LR/Jag engines were built in the same factory side by side. The F150 blocks were modified at least with some oilways enlarged that weren't replicated in the LR/Jag blocks. The slippers were tabbed on both engines but tabs are only to ensure that the slippers are installed correctly as tabs won't stop a grabbed slipper from turning. Kings bearings (same part number for LR/Jag and F150) don't have tabs even for these later engines. |
9th Dec 2024 8:19am |
So do we know if there is a date or engine number that these improvements were incorporated and if since doing so crankshaft failures have stopped, or significantly reduced?
9th Dec 2024 8:21pm |
