Home > Technical (L405) > L405 3.0 TDv6 Crankshaft failure (rumours & facts)
Page 7 of 7 <1234567
Gremlin500
The early V6 ones have an M14 crankshaft pulley bolt, the improved ones have an M16 pulley bolt, so easy to check when you view a potential purchase. I’m happy to be corrected, as I don’t remember that source of information? I thought it must be on here somewhere…… Embarassed “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #706503 9th Dec 2024 9:30pm
GraemeS
Australia
IIRC the M14 bolts were D3/L320 TDV6. I'm pretty sure that my MY10 3.0 D4's bolt was 16mm. (now confirmed from Microcat 2012 LR013377)
I understand that Gen 2 engines have tabbed bearing slippers which were fitted to the F150 engine from the outset so perhaps Gen 2 engines also got the F150's updated crankshaft.
Post #706507 9th Dec 2024 11:01pm
Mikey
We've a Gen2 in just now, with a failed crank.
Serviced every 8k miles, meticulous service history, still failed Neutral
Post #706515 10th Dec 2024 7:20am
JayGee
The fundamental issue with the V6 is it's a 6 cylinder engine squeezed into a 4 cylinder size block and crank so no amount of updates to internals, service intervals or oil grades are going to totaly resolve the issue of 'waffer' thin webs beween the crank bearings and big ends. The only geniuine solution to this issue is to buy a V8...... 2012 TDV8 Vogue (L322)
Post #706517 10th Dec 2024 7:52am
GraemeS
Australia
I'd be real interested in learning the condition of the mains including the uppers although the sputter type lower mains and upper big-ends apparently aren't the magic bearing they were thought to be.
Post #706536 10th Dec 2024 11:00am
