Home > Technical (L322) > First problem? Intermittent Judder. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
A thought:
18th Feb 2020 5:56pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
I did think brake caliper. They were refurbed by previous owner. Next time it does it I will try and stab the brakes to see if it stops it.
18th Feb 2020 7:04pm |
If there's one sticking I doubt stabbing the brakes will clear it. And you said the previous owner rerfurbed them. Hmmmm. Did he do them himself?
18th Feb 2020 7:10pm |
New slides etc were ordered, I have a receipt. Not internal refurb I am guessing..
18th Feb 2020 7:43pm |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
On my previous 2008 TDV8 the same symptom was caused by one of the four pistons in the front driver side calliper which had delaminated a little so wasn't moving properly and would stick. I replaced all the pistons on that side and it never happened again. Good quality pistons from Brakes International - they sell Budweg German pistons which are I'm told better than the factory fit and their customer service is superb. |
18th Feb 2020 8:24pm |
Thanks WB. Guess I will be checking the calipers this weekend.
18th Feb 2020 8:37pm |
Definitely don't spray oil anywhere near your callipers!
18th Feb 2020 8:53pm |
No problem. That was my sense of humour btw. 2011 4.4tdv8 Vogue
18th Feb 2020 9:05pm |
+1 on checking the calipers at the weekend.
18th Feb 2020 9:06pm |
Purchased from Cossy and he did all of this more than once. I will dig through receipts and see what brake work was done. 2011 4.4tdv8 Vogue
18th Feb 2020 9:31pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
Sticking calliper.
18th Feb 2020 9:33pm |
2011 4.4tdv8 Vogue
18th Feb 2020 10:10pm |
Checked receipts and rear calipers had repair kit and sliders from Bearmach. Are the fronts more like to cause this than the rears? Any experience on this? 2011 4.4tdv8 Vogue Baltic Blue |
18th Feb 2020 11:38pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
From memory Bearmach do rear callipers for 50 quid not sure of the quality I always fit original where brakes are concerned but have a look |
19th Feb 2020 6:28am |
