Home > Technical (L322) > First problem? Intermittent Judder.
gavinn
Exactly the same happened to me, was a rear caliper sticking , diagnosed by pulling over and just feeling which wheel was the hottest, refurbed using a kit from Frentech [url]https://www.frentech-uk.co.uk/ [/url] which included all seals and new pistons, not a difficult job, one tip put the piston seal in the caliper , then fit the dust seal (as you can not get the dust seal in once the piston is in place ) then push the piston in after first stretching the dust seal over the piston , its a bit of a fiddle but patience helps and taking the caliper off and doing on a bench , normally there is a bit of crud at the start of the piston bore which needs to be cleaned off, as the seal for the piston is between the square edge seal grove and the piston body this is not an issue and can be achieved with a bit of wet and dry, obviously clean everything in there with a quality brake cleaner before assembly.
The whole thing cost me around £40
Post #544383 19th Feb 2020 7:27am
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Perfect. I will check this.
Funnily enough the wheels are refurbed and one has a lot of fine cracking all over it. I wonder if the wheel is getting really hot.
Cannot see it getting that hot but who knows! 2011 4.4tdv8 Vogue
Baltic Blue
Post #544389 19th Feb 2020 9:13am
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Similar experience with a sticky rear caliper here too .. however a new caliper was the same price as the refurb kit mentioned above 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #544397 19th Feb 2020 10:19am
DMRR
If it feels like a puncture but has no feedback in the steering it's a caliper sticking. I've replaced 3 so far Rolling with laughter Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #544398 19th Feb 2020 10:19am
gavinn
This Kit did both calipers and to be honest i prefer to recon myself keeping as much as the original equipment as possible , but i agree its far easier sticking on a recon caliper
Post #544401 19th Feb 2020 10:47am
Gazcw
Well it definitely has a OS rear caliper sticking. Lots more brake dust on the wheel and much hotter. No need to touch it. You can smell and feel the heat coming from it. I have my job for the werkend. As they have had new seals and slides I guess it must be a piston issue so will probably replace the caliper and then rebuild it for next time. 2011 4.4tdv8 Vogue
Baltic Blue
Post #544710 21st Feb 2020 4:10pm
Gazcw
I needed one quick so bought from eurocarparts. With brake cleaner and a roll of blue tissue they came to £126. That included a £30 exchange charge. I am going to refurb mine so won't be sending back.
It was advertised as pagid but actually a refurb TRW caliper. Came with slider grease and replacement slide rubbers too. Sorted.
Now need to refurb wheel as it got so hot the coating is cracked all over. 2011 4.4tdv8 Vogue
Baltic Blue
Post #545406 27th Feb 2020 10:58pm
coopss
@gazcw: did you replace the rotor as well or just the calliper? 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #563504 3rd Aug 2020 7:30pm
