![]() | Home > Technical (L322) > First problem? Intermittent Judder. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
A thought:
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
I did think brake caliper. They were refurbed by previous owner. Next time it does it I will try and stab the brakes to see if it stops it.
If there's one sticking I doubt stabbing the brakes will clear it. And you said the previous owner rerfurbed them. Hmmmm. Did he do them himself?
New slides etc were ordered, I have a receipt. Not internal refurb I am guessing..
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
On my previous 2008 TDV8 the same symptom was caused by one of the four pistons in the front driver side calliper which had delaminated a little so wasn't moving properly and would stick. I replaced all the pistons on that side and it never happened again. Good quality pistons from Brakes International - they sell Budweg German pistons which are I'm told better than the factory fit and their customer service is superb. |
Thanks WB. Guess I will be checking the calipers this weekend.
Definitely don't spray oil anywhere near your callipers!
No problem. That was my sense of humour btw. |
+1 on checking the calipers at the weekend.
Purchased from Cossy and he did all of this more than once. I will dig through receipts and see what brake work was done. 2011 4.4tdv8 Vogue
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Sticking calliper.
Checked receipts and rear calipers had repair kit and sliders from Bearmach. Are the fronts more like to cause this than the rears? Any experience on this? 2011 4.4tdv8 Vogue Baltic Blue |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
From memory Bearmach do rear callipers for 50 quid not sure of the quality I always fit original where brakes are concerned but have a look |
