Home > Technical (L322) > 4.4 TDV8 Engine Problem - Help! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Odd noise, hard to say.
17th Feb 2020 11:21pm |
jjjjs5518 Member Since: 17 Sep 2018 Location: london Posts: 26 |
Apparently no codes are being thrown - I have had a garage read them already... |
18th Feb 2020 12:10am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Take it to a specialist independent LR expert and not an "ordinary" garage. The former will know these engines much better than a tin pot garage. Where are you located for a recommendation we can give?
18th Feb 2020 7:16am |
PS Only fit new Duracell batteries to your key fob and not cheap ones
18th Feb 2020 7:18am |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 370 |
Does it do it with a full tank of fuel? It will not do a regen on less than a quarter of a tank, I wonder if it is on the border line of this starting to do a regen than stopping because parameters not right hence fuel smell. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
18th Feb 2020 10:07am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
JJ
18th Feb 2020 12:10pm |
3 posts . He’s gone for good Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Feb 2020 5:37pm |
Thanks for the help everyone, not quite gone for good haha.
19th Feb 2020 12:14am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8665 |
The chirping noise on switch off is probably the EGR self cleaning. There is nothing that can't be fixed with a hammer😜😜
19th Feb 2020 1:38am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2541 |
The chirping could be a belt idler pulley or the tensioner if its only a chirp or 2 as the engine stops. |
19th Feb 2020 3:49am |
come to think of it its more like a releasing of pressure kind of whoosh noise
19th Feb 2020 8:47pm |
Get it to a specialist for a once over
19th Feb 2020 9:02pm |
Probably a good idea!
19th Feb 2020 9:45pm |
Try RR London in..........Battersea
19th Feb 2020 9:53pm |
