![]() | Home > Technical (L322) > 4.4 TDV8 Engine Problem - Help! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Odd noise, hard to say.
jjjjs5518 Member Since: 17 Sep 2018 Location: london Posts: 26 ![]() ![]() |
Apparently no codes are being thrown - I have had a garage read them already... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Take it to a specialist independent LR expert and not an "ordinary" garage. The former will know these engines much better than a tin pot garage. Where are you located for a recommendation we can give?
PS Only fit new Duracell batteries to your key fob and not cheap ones |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Does it do it with a full tank of fuel? It will not do a regen on less than a quarter of a tank, I wonder if it is on the border line of this starting to do a regen than stopping because parameters not right hence fuel smell. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
JJ
3 posts . He’s gone for good |
Thanks for the help everyone, not quite gone for good haha.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8716 ![]() ![]() ![]() |
The chirping noise on switch off is probably the EGR self cleaning. There is nothing that can't be fixed with a hammer😜😜
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2585 ![]() ![]() ![]() |
The chirping could be a belt idler pulley or the tensioner if its only a chirp or 2 as the engine stops. |
come to think of it its more like a releasing of pressure kind of whoosh noise
Get it to a specialist for a once over |
Probably a good idea!
Try RR London in..........Battersea |
