Home > Technical (L322) > Clicking sound from rear nearside
Chlorothalonil
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
Second fault on my new TDV8 L322 VSE 2008 is what sounds like a relay clicking regularly, sounds like it is coming from under the car near the rear nearside wheel.
It just sounds like the hazards are on, that type of clicking.
Any ideas what it could be please?
Post #543512 9th Feb 2020 7:33pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I believe that it is the second fuel pump?
Jim
Post #543515 9th Feb 2020 8:02pm
Chlorothalonil
Is that for the FBH? Is there any way of fixing it? Thanks.
Post #543516 9th Feb 2020 8:09pm
jim4244
So apart from the ticking noise is everything working as it should?
Post #543520 9th Feb 2020 8:51pm
Chlorothalonil
Seems to be.
Post #543522 9th Feb 2020 9:03pm
rjff
Sounds like the FBH pump. Clicks about once per second then moves to about twice per sceond if the FBH demand goes to full. Should run from this time of year cold until the engine coolant reaches a predetermined a set point.
Do you have park heating/ ventilation enabled and a remote for the FBH? Cheers
Richard
Gap IIDBT
Post #543524 9th Feb 2020 9:34pm
Chlorothalonil
Not on the timer and don't have the remote unfortunately.
It seems to start when I start the engine and continues when driving.
Post #543527 9th Feb 2020 10:06pm
rjff
Not sure of you can enable the park heating timer on yours, someone on here may be along to say if it'spossible. The WM in the Wiki may help.
On running, it will (should) cut out as I said when the engine is hot enough. I think that it runs to ensure the engine reaches operating temperatue more rapidly to reduce emissions, and wear. Cheers
Richard
Gap IIDBT
Post #543529 9th Feb 2020 10:32pm
Chlorothalonil
Thanks, I will double check and see what it does when it has been on s run. Not bad it long. Good to know the clicking isn't unusual.
Post #543530 9th Feb 2020 10:33pm
