Home > Technical (L322) > Clicking sound from rear nearside |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
I believe that it is the second fuel pump?
9th Feb 2020 8:02pm |
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 53 |
Is that for the FBH? Is there any way of fixing it? Thanks. |
9th Feb 2020 8:09pm |
So apart from the ticking noise is everything working as it should? |
9th Feb 2020 8:51pm |
Seems to be. |
9th Feb 2020 9:03pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Sounds like the FBH pump. Clicks about once per second then moves to about twice per sceond if the FBH demand goes to full. Should run from this time of year cold until the engine coolant reaches a predetermined a set point.
9th Feb 2020 9:34pm |
Not on the timer and don't have the remote unfortunately.
9th Feb 2020 10:06pm |
Not sure of you can enable the park heating timer on yours, someone on here may be along to say if it'spossible. The WM in the Wiki may help.
9th Feb 2020 10:32pm |
Thanks, I will double check and see what it does when it has been on s run. Not bad it long. Good to know the clicking isn't unusual. |
9th Feb 2020 10:33pm |
