Home > Technical (L405) > Tpms ??
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Tpms ??
If I put new wheels on without tpms and my old wheels had tpms would it show an error?
Post #542692 1st Feb 2020 8:26pm
Vogue
Yes - warning on dashboard - irritating but can just ignore 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #542700 1st Feb 2020 9:27pm
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Does the warning on the dash not cause MOT failure? 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #542704 1st Feb 2020 9:56pm
Vogue
No idea as not MOT’d it. I only know about the warning as I have two sets of wheels and tyres. Would have thought it was likely to cause a fail though - May depend on your examiner though.... 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #542723 2nd Feb 2020 4:48am
pld118
Any car registered after 1st January 2012 that is fitted with TPMS will fail its MOT if the TPMS warning light is displayed.
https://www.kwik-fit.com/blog/drivers-risk...unserviced
Post #542724 2nd Feb 2020 5:15am
Felstmiester
As much as I don’t care for the tpms. I don’t think I would want to live with a warning light on all the time.
What’s the recommendations? Swap old units from existing wheels to new or order a new set?
Post #542739 2nd Feb 2020 9:17am
Does the car definitely have TPMS ? If you lower a pressure you get a warning on the dash ?
I can't remember when it became compulsory - mine doesn't have it, but I have one set of wheels with sensors & another without.
If your car has TPMS, then you can get the sensors swapped over at a tyre place - then rebalanced - or buy an additional set of sensors - depending what you're planning for the old wheels.
Alternatively - you might be able to turn TMPS & hence the error message, off using an IID tool
Post #542741 2nd Feb 2020 9:24am
Felstmiester
Alistair. Yes the car definitely has it. I did a bit of research yesterday and it seems you can’t disable the tpms with a IID tool.
I think I will just swap to the new wheels.
Post #542743 2nd Feb 2020 9:34am
dingg1
I disabled my tpms with an iid tool
Post #542744 2nd Feb 2020 9:50am
I was able to disable TMPS with IID on my L322 but suspect you can't on later L405's.
It seems it became a mandatory feature on Jan 1 2015, so I guess you'll need sensors - it will fail the MOT otherwise
Post #542745 2nd Feb 2020 10:08am
supershuttle
Or just borrow a set of wheels with TPMS to get it through - just saying Whistle Geoff
Post #542751 2nd Feb 2020 10:54am
Felstmiester
on what model?
Post #542754 2nd Feb 2020 11:10am
dingg1
2007 sc
Post #542755 2nd Feb 2020 11:15am
Felstmiester
Ok so it seems I’ve got to stick with tpms as don’t want a light up and apparently 13 or later cars can’t be disabled.
My second dilemma is...... any recommendations of where to get tyres fitted & balanced? I’m thinking somewhere like kwik fit where they’ve got all the latest machines.
Post #542770 2nd Feb 2020 2:19pm
GAP do provide a un-tested ccf list on request and i'm not 100% sure but you might be able to switch it off with that.. ... - .- -.
Post #542779 2nd Feb 2020 3:08pm
