Home > Technical (L322) > What was that smoke??? |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 |
Regardless of; the year, make or model of vehicle; NEVER disconnect the car battery while the engine is running or the ignition key is turned on. Disconnecting the car battery can create; a high voltage spike in the electrical system; that may damage electronic modules. |
7th Jan 2020 1:52pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Yes it was a mistake to pull while ignition was on.
7th Jan 2020 2:06pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Smoke is what makes components work. Usually if smoke escapes from a component it rarely works again and needs replacing Previous cars:
8th Jan 2020 9:11am |
xjsracer44 Member Since: 29 Nov 2010 Location: Hertfordshire Posts: 274 |
8th Jan 2020 12:10pm |
