![]() | Home > Technical (L322) > What was that smoke??? |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
Regardless of; the year, make or model of vehicle; NEVER disconnect the car battery while the engine is running or the ignition key is turned on. Disconnecting the car battery can create; a high voltage spike in the electrical system; that may damage electronic modules. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Yes it was a mistake to pull while ignition was on.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Smoke is what makes components work. Usually if smoke escapes from a component it rarely works again and needs replacing |
xjsracer44 Member Since: 29 Nov 2010 Location: Hertfordshire Posts: 274 ![]() ![]() ![]() |
