Home > Technical (L322) > fault code uo167 |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 |
Do you have any symptoms? Or just a fault code? 2016 Skoda Octavia VRS Estate
8th Jan 2020 11:09am |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 |
battery drain is the worse |
8th Jan 2020 11:15am |
It's likely that fault code is a symptom of a low battery rather than the cause. 2016 Skoda Octavia VRS Estate
8th Jan 2020 11:36am |
