Home > Technical (L405) > windscreen replacement |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35363 |
has anyone had this done and noticed where the heated screen connections are located.
7th Jan 2020 11:34am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Stan,
7th Jan 2020 12:25pm |
yes both sides dont work and yes there are 2 relays as in the L322 Mike.....
7th Jan 2020 1:24pm |
best wishes.
7th Jan 2020 1:26pm |
1JBS Member Since: 18 Feb 2014 Location: Henley on Thames Posts: 171 |
Stan
7th Jan 2020 3:43pm |
i dont know if its the screen or the electrics feeding the screen, but thats a good call re trying another dealer..
7th Jan 2020 3:52pm |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 |
In my area, Grange do sometimes and Lookers don't.
7th Jan 2020 5:07pm |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 555 |
I I R C, the feeds are from the A Pillars. Had one done a few years ago and seem to remwmber the connections there. Tony
7th Jan 2020 5:29pm |
i thought 'a' pillars as well...
7th Jan 2020 5:41pm |
"@huw, it is an extended but dealer says that doesnt cover if the fault is in the glass ie broken element..."
7th Jan 2020 6:08pm |
thanks for the tip..i'll do that.. ... - .- -.
7th Jan 2020 6:13pm |
thank you for contributing to my thread with two helpful posts John.. ... - .- -.
7th Jan 2020 7:42pm |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
The wiring for the 2 sides of the heated front screen is from a junction box in the engine bay .The relay is common to both sides and after that the 12 v feed splits into 2 , each of which is protected by a 40amp fuse . I suppose you could use a test meter in these points ( with the engine running ) . If there is no 12V at the relay then its down to the switch itself or the body control module . If there is 12v at the fuses then its the screen or more likely the connection to it . If you have a diagnostic then you will be able to see the BCM go live ? |
7th Jan 2020 8:33pm |
very helpful Charlie , thankyou... ... - .- -.
7th Jan 2020 9:24pm |
