Home > Technical (L405) > windscreen replacement
has anyone had this done and noticed where the heated screen connections are located.
my screen doesnt heat so i figure i'd check if theres any power going to it where these connections are.. ... - .- -.
Post #539704 7th Jan 2020 12:34pm
Baltic Blue
Stan,
Is it both sides that don’t work ?
If it’s like the 322 it has separate feeds from the relay to LHS and RHS.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #539711 7th Jan 2020 1:25pm
yes both sides dont work and yes there are 2 relays as in the L322 Mike.....
its under warranty but the dealer says that they charge £175 as a diagnostic fee and if its the screen then i lose that amount and if its electrical then i dont as the warranty will pay for it.
hence my efforts to see which is which.... ... - .- -.
Post #539717 7th Jan 2020 2:24pm
Baltic Blue
Thumbs Up best wishes.
Post #539718 7th Jan 2020 2:26pm
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Hi Stan
How can it be anything but electrical? The screen is two pieces of glass with an element in a membrane. The element connects to power via a switched relay so how can the screen become "the cause"???
Is the screen broken/cracked?
Confused
Post #539730 7th Jan 2020 3:35pm
1JBS
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Stan
FYI I had the same problem with one half of my 2012 Range Rover Sport Screen it was under Land Rover Approved Used warranty and Car Care Plan paid for a new genuine screen.
You need to find a nicer main dealer who doesn't rip you off with diagnostics charges, there are some out there who don't charge!
Post #539737 7th Jan 2020 4:43pm
i dont know if its the screen or the electrics feeding the screen, but thats a good call re trying another dealer.. Thumbs Up
@huw, theres one small stone chip on the drivers side and if that was the cause then the passenger side would work, unless both sides have filament damage .. ... - .- -.
Post #539739 7th Jan 2020 4:52pm
Huwrhys
In my area, Grange do sometimes and Lookers don't.
Why are they not covering glass under warranty? Is it an extended warranty?
I imagine the stone chip could very easily cause the fine filament to break if it's deep enough. I'd be worried the glass may well crack completely if it were that deep and then you'd have to change it anyway.
I'd get the local windscreen company to have a look as the Indy glass guys are usually a good bunch. They'll know where to look and won't charge anything like what LR dealerships will. They'll also tell you if it's legal to drive with the deep chip that you have.
Very Happy
Post #539744 7th Jan 2020 6:07pm
Big Boy R44ROV
I I R C, the feeds are from the A Pillars. Had one done a few years ago and seem to remwmber the connections there. Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #539747 7th Jan 2020 6:29pm
i thought 'a' pillars as well... Thumbs Up
@huw, it is an extended but dealer says that doesnt cover if the fault is in the glass ie broken element...
i think my next step is to get them pillars off..
thanks all.. Wink ... - .- -.
Post #539748 7th Jan 2020 6:41pm
1JBS
"@huw, it is an extended but dealer says that doesnt cover if the fault is in the glass ie broken element..."
Not true speak to Car Care Plan directly they covered mine in full..!
Post #539755 7th Jan 2020 7:08pm
thanks for the tip..i'll do that.. ... - .- -.
Post #539756 7th Jan 2020 7:13pm
thank you for contributing to my thread with two helpful posts John.. Rolling Eyes ... - .- -.
Post #539764 7th Jan 2020 8:42pm
charlie croker mk2
The wiring for the 2 sides of the heated front screen is from a junction box in the engine bay .The relay is common to both sides and after that the 12 v feed splits into 2 , each of which is protected by a 40amp fuse . I suppose you could use a test meter in these points ( with the engine running ) . If there is no 12V at the relay then its down to the switch itself or the body control module . If there is 12v at the fuses then its the screen or more likely the connection to it . If you have a diagnostic then you will be able to see the BCM go live ?
Post #539772 7th Jan 2020 9:33pm
very helpful Charlie , thankyou... Thumbs Up ... - .- -.
Post #539773 7th Jan 2020 10:24pm
