![]() | Home > Technical (L322) > L322 Vogue 2011 Brake discs size? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
Regarding the judder, possibly caused by sticking caliper slide pin. Easily checked by a short run and then testing to see if one wheel is hotter than the others. John
Fatzo Member Since: 11 Nov 2016 Location: Rigny Posts: 82 ![]() ![]() ![]() |
Thanks for your answers guys!
Thinking about it, since the brake judder appeared after changing front discs and all pads (front and rear), I think the problem could be limited to the front wheels only.
Generally, if you feel the judder through the steering wheel it tends to be the fronts. Through your seat, it’s the rears.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
New discs may be faulty?
Yes I think they re faulty
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
![]() ![]() Mike |
I believe that should read 45mm single piston....
Well some news.
The extract I posted above is from the Range Rover brochure....
Ah, sorry for the confusion, in trying to find a pdf of the brochure for you to link to, I had to search the web, and the link is for the 3.6 TDV8.
