Home > Technical (L322) > L322 Vogue 2011 Brake discs size?
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
Hello all and happy new year!
Got a problem with my 2011 4.4 TDV8 vogue: front discs and pads were changed 6 monthes ago, but got now brake judder at some speeds.
Seller says discs could be warped and will order new ones.
I've looked through the forum and it appaears the problem could lie somewhere else.
However, could you tell me the size of front and rear brake discs?
These are different, right?
Thanks for your answers.
Fatzo
Post #539396 4th Jan 2020 6:08pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #539404 4th Jan 2020 7:15pm
Weegie
Regarding the judder, possibly caused by sticking caliper slide pin. Easily checked by a short run and then testing to see if one wheel is hotter than the others. John
GAP iiD BT
Post #539406 4th Jan 2020 7:16pm
Fatzo
Thanks for your answers guys!
Post #539418 4th Jan 2020 8:20pm
Fatzo
Thinking about it, since the brake judder appeared after changing front discs and all pads (front and rear), I think the problem could be limited to the front wheels only.
Fingers crossed!
Post #539419 4th Jan 2020 8:24pm
mjdronfield
Generally, if you feel the judder through the steering wheel it tends to be the fronts. Through your seat, it’s the rears.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #539429 4th Jan 2020 10:08pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
New discs may be faulty?
This is common i think... 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #539493 5th Jan 2020 4:41pm
Fatzo
Yes I think they re faulty
Going to get them replaced next Week...
Post #539506 5th Jan 2020 5:38pm
mpirie
mjdronfield wrote:
Shocked 45 piston rear caliper? They must be bloody small pistons! Rolling with laughter
Mike
Post #539583 6th Jan 2020 10:01am
mjdronfield
Rolling with laughter yeah I know, and that’s from the PDF brochure.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #539624 6th Jan 2020 4:34pm
mjdronfield
I believe that should read 45mm single piston....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #539655 6th Jan 2020 8:40pm
Fatzo
Well some news.
The seller says judder may have been caused by warped disc due to...oversized disc! Yawn
He says that when trying to find correct front brake discs for my car, websites point to lower sized discs.
I tried this and its confusing… Confused
I tried to ask official Range rover reseller size of the front discs for my RR, but he neither wanted to tell me nor the LR ref. of the item. Evil or Very Mad
I found online what seems the correct answer: LR031845 (380mm)
Is there any official document I can show to convince him?
Thank you all for your precious help
Fatzo
Post #539674 6th Jan 2020 10:25pm
mjdronfield
The extract I posted above is from the Range Rover brochure....
....page 52...
http://www.rangerovervoguefan.com/2010-ran...ochure.pdf
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #539679 6th Jan 2020 10:58pm
Fatzo
but according to page 52 of the Range Rover brochure you pointed to, 360mm is the front discs size for a TDV8 (my car is a 2011 4.4 TDV8)
I'm confused Shocked
Post #539691 7th Jan 2020 8:05am
mjdronfield
Ah, sorry for the confusion, in trying to find a pdf of the brochure for you to link to, I had to search the web, and the link is for the 3.6 TDV8.
The screenshot I put up is for the 4.4 TDV8 and it’s 380mm. There must be a 4.4 brochure online somewhere, I thought there was one in our Wiki but can’t see one.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #539694 7th Jan 2020 9:02am
