![]() | Home > Technical (L322) > Restricted Performance? Could this be the culprit? - FIXED! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
Great news! JGS doing starter and smoke? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Ok in the form of an update. Took the car to the garage today to get the Starter Replaced. They are also going to look into this dash warning.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Post up the code(s)....
Oh and read the codes with the RED on the dash Mark
It's this code:
Weird.
Measured it just when I left the garage, said 20.2g
You CAN clear a red dpf with IID. I did on mine.
I don't have a red DPF warning, I have a red Restricted Performance warning with the only fault code being the one above |
You defo need to track down any potential intake leaks with smoke test and go from there....
I'm going to let them do the smoke test and then ask them to swap those hoses over. I've put my new Samco ones in the boot so they have them there. |
I had a RP after the new secondary turbo was changed recently. They forgot to replace a vacuum hose. All fine one connected.
Yep you're DPF is fine Mark.
Not changed those hoses yet, after I snapped that water hose I got scared and put it all back together, making the decision to leave it to the professionals.
