Home > Maintenance & Mods (L322) > EAS sensor shaft
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
EAS sensor shaft
Bit of a heart stopping moment this evening.
After helping my work mate jumpstart his van, unsuccessfully, I drive home for the charger.
After arriving home ....eas on dash shows up....
Clear fault and go back to my mate and his van and....yes you got it ...eas and max 30mph pops up.
Heart stops thinking I know these FF are a bit sensitive but thinking the worst....
Well rethink what happened, looked under the FF and one broken shaft on the sensor..
Happy days...sort of.
Question, is the shaft a replaceable item or is it a new sensor. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #536742 8th Dec 2019 7:50pm
GraemeS
Microcat doesn't show that the link rod is available by itself, only as part of a sensor.
Post #536751 8th Dec 2019 9:06pm
If you are into mend and make do, you could screw a strip of flat bar to each side (two screws each side), if possible. Would keep you on the road.... (sometimes these fixes last for much longer than you expect) .
Post #536753 8th Dec 2019 9:41pm
Welshdragon
Thought so.
I been having a look see how much its going to cost.....can you believe prices range from £15 right up to £130! Shocked
Yep...buy cheap buy twice so Ill be looking at repair first then look at our sponsor here on this forum.
At least it did what it did when not towing the horses about Laughing If it dont work.......burn it!
Post #536756 8th Dec 2019 10:37pm
Welshdragon
Post #536757 8th Dec 2019 10:37pm
Ah, it is that end, a little more tricky to fix (was hoping it was the plastic arm Wink )
If the locating rubber end is still in fairly good condition, a good clean up, lots of glue and tape should get you back on the road .
Post #536759 9th Dec 2019 8:41am
Welshdragon
Quick temporary fix, hopefully it will do the job until I have spare time and day off work.
Now I'm wondering if a cheap sensor off eBay and use the rod only.
Nothing really wrong with the sensor to be fair. If it dont work.......burn it!
Post #536766 9th Dec 2019 12:04pm
Welshdragon
Yes, zip ties are a great invention with super glue 😂 If it dont work.......burn it!
Post #536767 9th Dec 2019 12:07pm
Thumbs Up Bow down .
Post #536770 9th Dec 2019 12:28pm
