Home > Maintenance & Mods (L322) > EAS sensor shaft |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Microcat doesn't show that the link rod is available by itself, only as part of a sensor. |
8th Dec 2019 9:06pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
If you are into mend and make do, you could screw a strip of flat bar to each side (two screws each side), if possible. Would keep you on the road.... (sometimes these fixes last for much longer than you expect) .
8th Dec 2019 9:41pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Thought so.
8th Dec 2019 10:37pm |
Ah, it is that end, a little more tricky to fix (was hoping it was the plastic arm )
9th Dec 2019 8:41am |
Quick temporary fix, hopefully it will do the job until I have spare time and day off work.
9th Dec 2019 12:04pm |
9th Dec 2019 12:07pm |
9th Dec 2019 12:28pm |
