Home > Technical (L322) > ZF5HP24 |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I've a sneaking suspicion that maybe RRPhil may be along sometime soon, and he's sure to help if you do some homework.
28th Nov 2019 3:51pm |
Life is an Adventure Member Since: 04 Feb 2013 Location: Trawsfynydd, Wales Posts: 4 |
Thank you
28th Nov 2019 3:57pm |
Hope it helps. Cheers
28th Nov 2019 4:05pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
You could start by having a 'mega flush' of the gearbox, this apparently flushes out 99% of the oil versus 60% of the by only doing a filter change.
28th Nov 2019 9:51pm |
I’ve let it drained for 2 days. It took 8.4lts to refill the box. A
29th Nov 2019 10:26am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
RRPhil is your man - I wouldn't waste time talking to anyone else
29th Nov 2019 11:19am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
It’s true. The post-2002 5HP24 does have a couple of vulnerabilities i.e. wear of the torque converter lock-up clutch friction plate, and failure of the B-clutch hub/C-clutch drum axial needle roller bearing. However, both these tend to fail at around the 100,000 mile mark and their replacement will then give you another 100,000 miles of use from the same transmission.
29th Nov 2019 3:14pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 313 |
This is why this forum is so good.
29th Nov 2019 8:38pm |
Thank you for this information. That answered all my questions and put my mind to rest. So a new torque converter and a rebuild gearbox will see me back on the road again 😀 |
2nd Dec 2019 2:51am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 806 |
might need to do this on my car
3rd Jul 2021 11:38am |
The transmission has to be removed from the vehicle to access the torque converter, but it isn’t necessary to dismantle the transmission, so no specialist knowledge of automatic transmissions is required. Any competent mechanic could do this bit.
4th Jul 2021 10:43pm |
thanks Phil - really appreciate the info - top man ! |
4th Jul 2021 10:49pm |
