Home > Technical (L322) > ZF5HP24
Life is an Adventure
2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
ZF5HP24
Hi
Newby here with a few questions.
I’ve bought a 2004 4.4 v8 with BRC lpg recently. (165k miles)
And as expected the list of repairs are already long.
First priority is the gearbox. It started to hunt between gears and manual and sport mode, well wasn’t operational.
So I’ve done a oil and filter change which sorted the problem but high lighted another problem. The torque converter judders badly and I’ve got the engine management light on.
I was told by a transmission specialist that there’s a bearing in the A clutch housing that fails as well. When I asked him about any upgrades to improve reliability of the gearbox he couldn’t answer me he said it only requires a rebuild.
I would like to improve things when it needs repair/ replacing.
Does any of you know of anything that can be improve on this gearbox like a uprated torque converter ( maybe with a lower stall speed) better/stronger clutch packs and valve body improvements.
Any help and advice will be greatly appreciated
Post #535747 28th Nov 2019 3:35pm
rjff
I've a sneaking suspicion that maybe RRPhil may be along sometime soon, and he's sure to help if you do some homework.
Search zf5hp24 on here and, no it's not near the bit where you put the coloured water. Smile (see haylands post now it begins)
Seri0usly, you may well find most of what you need on the posts in that search and on one for T/Cs, but others will be along to help. Cheers
Richard
Gap IIDBT
Post #535752 28th Nov 2019 3:51pm
Thank you
Will have a look at that post
Post #535754 28th Nov 2019 3:57pm
rjff
Thumbs Up Hope it helps. Cheers
Richard
Gap IIDBT
Post #535757 28th Nov 2019 4:05pm
Fox889
You could start by having a 'mega flush' of the gearbox, this apparently flushes out 99% of the oil versus 60% of the by only doing a filter change.
The gearbox is a well known weak point, but, having said that I've had a 5sp & 6sp in my time & had little trouble. Torque converter replacement isn't a hideous price but what I would recommend is a 'new' torque converter & not a recon one.
As before, RRPhil is the gearbox wizard & im sure he'll give word she of wisdom shortly. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #535797 28th Nov 2019 9:51pm
I’ve let it drained for 2 days. It took 8.4lts to refill the box. A
After some more reading here on the forum: I think that I played a big part in killing the torque converter as I’ve filled it with the wrong oil. I’ve ordered the service kit (oil/filter/gasket) from JGS4x4 and they promised me that it was the correct oil. The oil was red not the straw colour as described in the forum post. ( the oil I’ve drained out was lets say black with a red tint 😳)
The shift issues and not working in manual/sport was sorted after the service and is still changing smoothly. Apart from the torque converter which has the judders when pulling away and then above 50mph.
I’m planning on keeping the FFRR for a looooong time so it needs fixing properly.
Hence the reason why I’m looking for uprated parts to make it better/stronger. ( she will get 33”tyres later, I’m towing 3ton trailer regularly as well)
So far I’m unsuccessful in finding a upgrade torque converter nor clutch packs. ☹️
Post #535844 29th Nov 2019 10:26am
RRPhil is your man - I wouldn't waste time talking to anyone else
Hopefully this thread will explain why - https://www.fullfatrr.com/forum/topic38676.html
Post #535845 29th Nov 2019 11:19am
RRPhil
It’s true. The post-2002 5HP24 does have a couple of vulnerabilities i.e. wear of the torque converter lock-up clutch friction plate, and failure of the B-clutch hub/C-clutch drum axial needle roller bearing. However, both these tend to fail at around the 100,000 mile mark and their replacement will then give you another 100,000 miles of use from the same transmission.
With the bearing, I did look at the possibility of modifying the design to fit an uprated bearing with a higher static & dynamic load capacity but there is so little room available that you risk weakening other components. Only vehicles that spend a lot of time in 1st, 2nd & 3rd gears tend to see failures because there is no relative speed across the bearing in 4th gear, and it is unloaded in 5th gear because the A-clutch is disengaged.
With the torque converter, the lock-up clutch operation is highly sensitive to the friction modifier pack in the fluid (particularly when operating in controlled-slip mode where the LUC continually slips at around 3% to absorb torsional vibration due to the fact there is no spring damper in the clutch). It is critical, therefore, that only Mobil ATF LT71141/Lifeguard Fluid 5/Pentosin ATF1 fluid is used.
Although the 5HP24 was originally designed for 420Nm and the M62 4.4V8 engine produces 210kW/440Nm, the ZF 5HP24A transmission (which uses the same internal running gear, clutch packs, etc.) was used in the VW Phaeton behind the mighty 6.0 litre W12 engine and in the Audi RS6 Plus, whose Cosworth-developed engine produced 353kW/560Nm. Consequently, the post-2002 5HP24 (putting aside the two vulnerabilities already discussed) is a highly durable transmission in the L322 application with capacity to spare, and I personally don’t see the need to uprate it.
Phil
Post #535867 29th Nov 2019 3:14pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
This is why this forum is so good.
RRPhil - legend Bow down
Post #535890 29th Nov 2019 8:38pm
Thank you for this information. That answered all my questions and put my mind to rest. So a new torque converter and a rebuild gearbox will see me back on the road again 😀
Post #536113 2nd Dec 2019 2:51am
pcourtney
might need to do this on my car
is the lock up clutch friction plate something that can be replaced in situ, or does the box have to come out ?
also, what are the tell tale signs of failure of the B-Clutch hub ?
do any codes pop up when scanning with IIDtool or other scanners to alert you to 5HP24 problems like this ?
Post #599510 3rd Jul 2021 11:38am
RRPhil
The transmission has to be removed from the vehicle to access the torque converter, but it isn’t necessary to dismantle the transmission, so no specialist knowledge of automatic transmissions is required. Any competent mechanic could do this bit.
However, replacing the torque converter lock-up clutch friction plate is a highly specialised job which involves first splitting the converter apart by turning off the weld on a lathe.
The spring retainer for the LUC piston is friction welded into position on the centre tower so this weld also has to be cut off to allow the piston to be removed to provide access to the friction plate.
Once the friction plate is replaced, the spring retainer has to be very accurately re-welded back into position (total piston movement is only around 1mm) before the complete assembly can be welded back together, pressure tested and balanced.
There are few companies in the UK capable of doing this. Those with the capability include JPAT, Sussex Autoparts & Mackie Transmissions.
When the B-clutch hub/C-clutch drum axial needle roller bearing fails it will cause an O-ring between the input shaft and B-clutch drum to split and this causes a hydraulic leak in the A-clutch circuit. You’ll know if this happens because, once the fluid gets warm, the failsafe message will be displayed and the transmission will lock in 5th gear.
Phil
Post #599661 4th Jul 2021 10:43pm
pcourtney
thanks Phil - really appreciate the info - top man !
Post #599662 4th Jul 2021 10:49pm
