![]() | Home > Maintenance & Mods (L322) > Howto: FFRR '02 TD6 - Change a Diesel Injector |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
I’ve just had mine tested at British turbo parts as they are local to me.They said I only needed one. Result! Was expecting two or three after 146k miles.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
When I rebuilt it started pretty quickly tbh. Check you have the loom connected to t the injectors and it hasn't come apart anywhere whilst fiddling, also check all your bleed off pipes are fitted.
Darryl72 Member Since: 25 Oct 2016 Location: East Sussex Posts: 62 ![]() ![]() ![]() |
Thanks for this informative post Joe, Im crossing my fingers for a dry weekend to replace one one mine. |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
When I replaced my injectors I was advised by the injector company to use a seat cutting tool to ensure a good seal against the copper washer and the cylinder head.
Do you need to let the pressure out before moving the fuel rail? |
No, but have a rag handy |
