Home > Maintenance & Mods (L322) > Howto: FFRR '02 TD6 - Change a Diesel Injector
Paul thornton
I got mine off a company called british turbo parts on eBay as recommended by another member on here.
£80 each on an exchange basis, luckily for me I only needed one.
I'd highly recommend buying a full leak off kit for the injectors, pipes , plastic connectors, rubber seals etc and replace all those whilst your at it otherwise you'll end up in the same situation as me with leaks at the top of the injectors and end up having to pull it all apart again.
Post #496683 26th Nov 2018 4:26pm
Andy
I’ve just had mine tested at British turbo parts as they are local to me.They said I only needed one. Result! Was expecting two or three after 146k miles.
I’ve just put it all back together but it won’t start now. I assume it’s self bleed and will start eventually?
Post #498484 13th Dec 2018 7:40pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
When I rebuilt it started pretty quickly tbh. Check you have the loom connected to t the injectors and it hasn't come apart anywhere whilst fiddling, also check all your bleed off pipes are fitted.
Other than that yes, I believe it is self bleed.
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #498538 14th Dec 2018 9:20am
Darryl72
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Thanks for this informative post Joe, Im crossing my fingers for a dry weekend to replace one one mine.
Post #535719 28th Nov 2019 11:32am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
When I replaced my injectors I was advised by the injector company to use a seat cutting tool to ensure a good seal against the copper washer and the cylinder head.
They can be bought cheap enough.
Post #535768 28th Nov 2019 6:43pm
Darryl72
Do you need to let the pressure out before moving the fuel rail?
Post #535790 28th Nov 2019 10:25pm
No, but have a rag handy Thumbs Up .
Post #535795 28th Nov 2019 10:41pm
