Home > Maintenance & Mods (L322) > EGR valve on a 4.4
Page 2 of 3 <123>
Baltic Blue
On my last MOT the tester could not get any reading only Zero, so he repeated the test with lots of revs but it still read Zero and he could not print out the results, so he just signed it and said, it’s fine.
Post #506721 28th Feb 2019 5:15pm
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
And they say diesels are the worst polluters Sheep
Post #506725 28th Feb 2019 5:45pm
rjff
Glad to hear you passed, Cavalier.
Like Mike's, mine had the same result. Cheers
Richard
Gap IIDBT
Post #506726 28th Feb 2019 6:10pm
DrRob
I’m still intrigued about the blanking and mapping out of the EGR....more details Cavalier please Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #506735 28th Feb 2019 8:12pm
Cavalier
Well here is something I have never seen before I had the engine remapped and the EGR deleted.
On a run from Coventry to Milton Keynes, a combination of motorway and country roads, cruise control at 50mph through road works and 70mph when unrestricted.
Another thing I've noticed, the engine ticks over nearly a 100rpm slower after the remap.
Post #507065 2nd Mar 2019 9:33pm
GraemeS
I'm itching to get mine's EGR mapped out but not desiring any extra performance, the cost is hard to justify although I've not considered any financial benefit from an anticipated reduced fuel consumption.
Post #507076 2nd Mar 2019 10:14pm
GGDR
Yes details please, BHP, cost , who did it?
. Cheers, Greg
Post #507083 2nd Mar 2019 10:55pm
Cavalier
I had the remap done by a company called (Remap Kings) a bit of a naff name I know, they charge £295 to remap a Range Rover, not bad as they have to remove the ECU. They had a promotion on during January and February of a £100 off, so I paid £195. You pay a £50 deposit when you make a booking and the balance when you are satisfied with the result.
Whey they came to me I explained I was concerned the the toque on the gearbox was nearing its maximum of 700Nm and I was looking for a bit more pick up from a standing start. The 4.4 has plenty go when it's on the move.
The map produced 68 more BHP and an increase in toque of 70Nm, other map specs I have seen show Toque increase of 100Nm or more so I was satisfied with this nominal increase. At the end of the remap they do a error code test, mine should I had an error code for the EGR valve, he offered to turn the valve off in the map and If I had any problems or my Indy (who was on holiday at the time) felt it should not be turned off he would, when he was in my area again turn it back on again. Anyway I bought an £8 blanking plate off eBay to complete the job, took 10 minutes. As you can see from my earlier posts I have had the emission tested as all OK. To sum up all I can say is the car runs much better especially from a standing start. I have intentionally done lots of short journeys, to see if I can encourage the DPF warning light to come on, no problem as yet. Plus the thought of all that gunk not going back through the manifold makes me feel better. Time will tell.
Post #507120 3rd Mar 2019 11:51am
DrRob
Interesting Thumbs Up
Silly question but do you have a rotary gear selector or a more conventional lever? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #507121 3rd Mar 2019 12:02pm
Cavalier
Rotary gear change, 2012 model Thumbs Up
Post #507132 3rd Mar 2019 1:22pm
GraemeS
My thoughts exactly. Plenty of pickup if the throttle is pressed hard enough to keep 2000+ rpm but there should not be any need for such revs and noise. I wonder if just a little more torque at 1200-1300 rpm would satisfy the gearbox torque requirement to allow the torque converter to be locked - either that or reprogram the gearbox which isn't an option. When I idle along roughish tracks (eg my 2km driveway) probably in 3rd gear the engine pulls like the proverbial steam train at 1000-1200 rpm, with the TC obviously locked or at least with minimal slip.
Post #507203 3rd Mar 2019 7:59pm
DrRob
Cavalier - how are you getting on with the remap and EGR blank? What are the main improvements? Mpg? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535202 23rd Nov 2019 10:20am
Cavalier
Well after about 3000 miles, mostly towing a big caravan, I must say I have noticed improved mpg also smoother qicker standing starts. I had the DPF light come up on holiday, I used the car every day for short 10 mile journeys for 3 weeks. This cleared on my home journey. The car is due its annual service and mot in December, I expect it to pass with flying colours, but I will let you know.
Post #535214 23rd Nov 2019 11:41am
DrRob
Cool. Keep us posted. Really interesting topic Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535215 23rd Nov 2019 11:58am
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Cavalier
What EGR Blanking Kit did you use ? I can't see any listed on E-bay at present !
Laurie
Post #535286 24th Nov 2019 5:58am
Page 2 of 3 <123>
