Home > Maintenance & Mods (L322) > EGR valve on a 4.4
Page 1 of 3 123>
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
EGR valve on a 4.4
Does a 2012 4.4tdi only have one EGR valve?
Post #503537 1st Feb 2019 9:46am
rjff
As far as I can see yes, just the one. Why Smile Cheers
Richard
Gap IIDBT
Post #503551 1st Feb 2019 11:05am
GraemeS
Definitely only 1 EGR valve, with the exhaust feed from about the middle of the cross-over pipe.
Post #503563 1st Feb 2019 11:45am
Cavalier
Was scanning through the blanking plates on e.bay and noticed that for a late l322 they only offer a single plate. When I had an earlier Disco it was all the rage to blank them off but they had two. Thumbs Up
Post #503597 1st Feb 2019 5:36pm
Cavalier
Post #503598 1st Feb 2019 5:37pm
rjff
Looking at the comments about blanking off the EGR on 11MYs, I think it's not possible with them as its part of the system required for emission control etc. to meet the requirements brought in. Removing the EGR bits will make the FF fail the MOT.
Do a search and you may find lots of information from others more in the loop than me Sad Cheers
Richard
Gap IIDBT
Post #503620 1st Feb 2019 10:30pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
If be more concerned about the role EGRs play in the DPF cycle. I thought they were essential to the regen function? Without a functioning EGR I think the DPF will simply soot up. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #503623 1st Feb 2019 11:11pm
MikeO
(They are required for the MoT but practically speaking it's not possible for the tester to tell they've been blanked} 2016 Skoda Octavia VRS Estate
Post #503624 1st Feb 2019 11:13pm
GraemeS
During DPF re-gens the EGR valve is closed to ensure that the correct amount of unburnt fuel and oxygen goes to the catalytic converter for it to produce enough heat for the DPF to do the regen. However I don't know if a blocked EGR valve might contribute to excessive particulates being produced which might therefore cause the DPF to clog more quickly.
Post #503629 2nd Feb 2019 6:40am
Cavalier
My remap chap said I have a fault code for the EGR, it does not show up on the dash, he has turned the EGR off in the map and I have inserted a blank. He assures me he has does this numerous times and it has never affect the DPF. He will come and turn the ERG back on if I decide to replace the faulty EGR. Time will tell, I intend to use the car for a lot of short journeys and try to bring the DPF light into play, then Italian tune it to see if it will clear.
Post #503678 2nd Feb 2019 3:10pm
rjff
Mike, Graeme,
I agree with you both on your posts. Probably me not being clear enough.
Cavalier,
IIRC the EGR assists on reducing the NOx emissions and it will be interesting to see if your EGR being turned off affects the emissions level at your next MOT, assuming you leave it off. Would it be worth it to have the emissions tested by a "friendly" tester, perhaps you could update this thread then? Cheers
Richard
Gap IIDBT
Post #503690 2nd Feb 2019 3:43pm
Cavalier
I dought it will fail on emissions as the engine will be running cleaner, I believe people with a smokey car have blanked their EGRs to get their car through the MOT.
Post #503714 2nd Feb 2019 6:54pm
DrRob
My understanding is the 4.4 tdv8 with the DPF cannot have EGRs blanked....? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #503727 2nd Feb 2019 7:53pm
dolph34
When i had my 4.4 tdv8 remapped i was offered to have the EGR turned off. I didn't as i have haven't heard of problems with EGR on the 4.4. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #503755 2nd Feb 2019 10:27pm
Cavalier
rjff wrote:
Mike, Graeme,
Cavalier,
IIRC the EGR assists on reducing the NOx emissions and it will be interesting to see if your EGR being turned off affects the emissions level at your next M you leave it off. Would it be worth it to have the emissions tested by a "friendly" tester, perhaps you could update this thread then?
Took the car to a MOT station yesterday to have the emissions tested, results below:
He tells me they are as good a result as you can get. ie Thumbs Up
I am taking my car to see my Indy next, I will have covered about 300 mixed miles by then, he is going to check out the system for any error codes.
Post #506719 28th Feb 2019 5:07pm
Page 1 of 3 123>
