![]() | Home > General > Late L322 or early L494 |
Clfno1 Member Since: 06 Nov 2019 Location: Barnsley Posts: 9 ![]() ![]() |
As an engineer that's a thing of beauty 😍😍 |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Damn right it is! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
You can have my 2011 4.4 tdv8 for £17K |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
That's a dangerous thing to say! 2010 4.4 TDV8 Vogue SE |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
At some time in MY14 production a twin drain was fitted. Its not quite the same pipework as the retro-fit item in that it's connection at the block is different. |
Was the TDV8 ever fitted in the L405? It hasn’t been for the last 3 years for sure. |
Sorry, meant SDV8. There are still some new/nearly new ones out there. Just want to see if they got the problems sorted |
I don’t know if this helps, but my own Sept 2017 build SDV8 needed to have a modified sub wiring loom (running from an internal oil sensor to the main wiring loom) fitted, after it caused an oil leak that damaged the electricals associated with the primary turbocharger.
