Home > General > Late L322 or early L494
Clfno1
As an engineer that's a thing of beauty 😍😍
Post #533397 7th Nov 2019 9:58am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Damn right it is! Thumbs Up Very Happy
Post #533399 7th Nov 2019 10:13am
DrRob
You can have my 2011 4.4 tdv8 for £17K Thumbs Up
Everything than can go wrong has been done Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #533410 7th Nov 2019 11:38am
kooky_guy
That's a dangerous thing to say! 2010 4.4 TDV8 Vogue SE
Post #533418 7th Nov 2019 1:14pm
Clfno1
Does anyone know if the oil blockage problem on the secondary turbo for the 4.4 TDV8 on the L322 was rectified on the later L405, or of that continues to be a problem?
Post #535035 21st Nov 2019 5:04pm
GraemeS
At some time in MY14 production a twin drain was fitted. Its not quite the same pipework as the retro-fit item in that it's connection at the block is different.
Post #535055 21st Nov 2019 7:38pm
Red Merle
Was the TDV8 ever fitted in the L405? It hasn’t been for the last 3 years for sure.
Post #535070 21st Nov 2019 9:11pm
Clfno1
Sorry, meant SDV8. There are still some new/nearly new ones out there. Just want to see if they got the problems sorted
Post #535173 22nd Nov 2019 8:51pm
Red Merle
I don’t know if this helps, but my own Sept 2017 build SDV8 needed to have a modified sub wiring loom (running from an internal oil sensor to the main wiring loom) fitted, after it caused an oil leak that damaged the electricals associated with the primary turbocharger.
That was at 30,000 miles and it’s been fine since, currently showing a gnat’s testicle short of 71,000 miles Thumbs Up
Post #535191 23rd Nov 2019 5:27am
