![]() | Home > Technical (L322) > L322 2005 TD6 Digital (hybrid) TV Tuner for touch screen |
BackinBlack Member Since: 10 Dec 2018 Location: Manchester Posts: 18 ![]() ![]() ![]() |
Re posted in in car electronics. Apologies
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
AH42-19CO63-AE works in my 2005 (2006 MY). Think it came out of an RR Sport. |
Thanks for the reply I'll have a search for that one. The one I got is a UH42-19C063-BB |
GDM, It looks similar but it has a square green connector that I don't have on mine. |
That's what I thought. I need to find out if the wiring for the FFRR is the same as the Sport or if the +ve and -ve are reversed?
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
When I changed my FFRR tuner over I bought from a guy on D3 forum and he was selling jag/LR hybrid tuners with epg on and it was plug and play, so I assume all the plugs are the same! But as I said if the colour and shape are the same it should work Current: TDV8 (3.6) RRS HSE
Just to clarify, Is the 2005 FFRR and 2007 Sport TV tuner wiring the same or are the +ve/-ve reversed, on different pins etc?
Sorry Stu the replys are a bit out of sync. I read loads of stuff on the D3 forum, lot's of great posts by Wiggs who I assume you got yours from. I agree with you that it should be plug and play and that the one I got was just a faulty unit, hence the puff of blue smoke. |
As this is a common question I thought I would try and get a list of what will and won't work. This is what I have found from the threads I have read.
Yes Wiggs that the chap I got an updated phone module from him too Current: TDV8 (3.6) RRS HSE
Wiggs isn't far from me, I emailed him a few days ago but he hasn't replied yet, I was on his website a couple of weeks ago regarding the Bluetooth module but it said he was away until 8th Nov. |
I am pretty sure I didn't have a lead to go into the square green socket either but it works fine. |
Thanks GDM, I found something from Wiggs on the D3 forum that said he didn't know either so I won't worry about that. Cheers |
