Home > Technical (L322) > L322 2005 TD6 Digital (hybrid) TV Tuner for touch screen
BackinBlack
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Re posted in in car electronics. Apologies
Any TV experts around please?
Just replaced my analogue tuner with a hybrid one XRA500180 and it went pop in a puff of smoke, guy I got it from assured me it was working cos he'd been watching it and it had been stored in a dry container after removal. From what I have read the XRA500060 was replaced by: XRA500070 which was replaced by XRA500180 and also used in RR sport. Can anyone please confirm if it is compatible and that the wiring is the same?
Many thanks
Brian
Post #534742 18th Nov 2019 9:02pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
AH42-19CO63-AE works in my 2005 (2006 MY). Think it came out of an RR Sport.
Post #534761 18th Nov 2019 10:18pm
BackinBlack
Thanks for the reply I'll have a search for that one. The one I got is a UH42-19C063-BB
Post #534764 18th Nov 2019 10:31pm
BackinBlack
GDM, It looks similar but it has a square green connector that I don't have on mine.
Post #534770 18th Nov 2019 10:41pm
stu
if all the connections are the same colour and shape on the unit and the plugs match colour and shape it should just be plug and play. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #534985 21st Nov 2019 8:00am
BackinBlack
That's what I thought. I need to find out if the wiring for the FFRR is the same as the Sport or if the +ve and -ve are reversed?
I have been doing lots of reading up so have a good idea what part numbers should and shouldn't work.
Post #534999 21st Nov 2019 10:28am
stu
When I changed my FFRR tuner over I bought from a guy on D3 forum and he was selling jag/LR hybrid tuners with epg on and it was plug and play, so I assume all the plugs are the same! But as I said if the colour and shape are the same it should work Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #535000 21st Nov 2019 10:50am
BackinBlack
Just to clarify, Is the 2005 FFRR and 2007 Sport TV tuner wiring the same or are the +ve/-ve reversed, on different pins etc?
Cheers.
Post #535001 21st Nov 2019 10:51am
BackinBlack
Sorry Stu the replys are a bit out of sync. I read loads of stuff on the D3 forum, lot's of great posts by Wiggs who I assume you got yours from. I agree with you that it should be plug and play and that the one I got was just a faulty unit, hence the puff of blue smoke.
Post #535002 21st Nov 2019 11:04am
BackinBlack
As this is a common question I thought I would try and get a list of what will and won't work. This is what I have found from the threads I have read.
AH42-19CO63-A* All variants work
UH42-19CO63-BB Should work but mine blew up?
AW93-14F641-AE Don't work
Post #535004 21st Nov 2019 11:28am
stu
Yes Wiggs that the chap I got an updated phone module from him too Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #535006 21st Nov 2019 11:53am
BackinBlack
Wiggs isn't far from me, I emailed him a few days ago but he hasn't replied yet, I was on his website a couple of weeks ago regarding the Bluetooth module but it said he was away until 8th Nov.
Post #535009 21st Nov 2019 12:37pm
GDM
I am pretty sure I didn't have a lead to go into the square green socket either but it works fine.
Post #535069 21st Nov 2019 10:02pm
BackinBlack
Thanks GDM, I found something from Wiggs on the D3 forum that said he didn't know either so I won't worry about that. Cheers
Post #535074 21st Nov 2019 10:45pm
