Home > Maintenance & Mods (L405) > IID tool "operation Failed E7" -brakes into mainte
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
If any folk on here have an IID tool and a L405 - have you ever had this error message if you try to set the parking brake into maintenance mode so you can change the rear pads?
"Operation failed E7"
- just to be clear I mean the IID tool giving the error message NOT the car.
thanks.
Post #506731 28th Feb 2019 7:17pm
Best to check with GAP... .
Post #506732 28th Feb 2019 7:35pm
Fleagle_UK
Yes they are already looking into it for me but i wanted to know if anyone else had the same problem.
Post #506737 28th Feb 2019 8:15pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
When I asked about E7 for the FBH, Gap said it just meant that the FBH didn't accept the command so possibly the same thing, the ABS ECU hasn't accepted the command you sent it. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #506756 28th Feb 2019 9:53pm
Fleagle_UK
We’ve got to the bottom of this. The EPB must be off before selecting the Maintenance/ service option on the IID Tool. Then it’s all fine and dandy. Razz
Post #508323 11th Mar 2019 6:54pm
Andy
So what is E7 in relation to testing the FBH then? That’s what I’m currently trying to do. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #534831 19th Nov 2019 6:32pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Following e7 for fbh I get the same with fault codes Flame out. And. Circulating fan electrical fault
Post #534838 19th Nov 2019 8:09pm
jackcramerr
Seen a few people here refer to IID tool. Isn't it an expensive tool ?
Post #534856 19th Nov 2019 10:02pm
@jackcramer
I understand it is now @ £150 to put your FFRR into a main dealer to just have your codes read / diagnostics, and that is before any work is done (although they will ensure your car gets scratched by the handwashers later...
Now that is expensive.
An IIDTool (or similar) will pay for itself again and again over the lifetime of your ownership of an FFRR if you want to fix it yourself .
Post #534866 19th Nov 2019 10:42pm
Dolphinboy
£180 + vat here in bristol Shocked Shocked
I told the dealer where to shove it and bought one straight away. Wished I’d done So years ago. Vital piece of kit. Thumbs Up
Post #534868 19th Nov 2019 10:55pm
jackcramerr
Not sure if I can fix things as it is a complex vehicle. Most I can do is a service and brake change.
Post #534965 20th Nov 2019 9:19pm
jackcramerr
So a off the shelf OBD scanner won't do?
Post #534966 20th Nov 2019 9:20pm
AFAIK a scanner will read fault codes.
An IID will read fault codes, but will also allow you to make changes to the CCF (Car Configuration File)
Post #534970 20th Nov 2019 9:36pm
