![]() | Home > Maintenance & Mods (L405) > IID tool "operation Failed E7" -brakes into mainte |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Best to check with GAP... .
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Yes they are already looking into it for me but i wanted to know if anyone else had the same problem. |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
When I asked about E7 for the FBH, Gap said it just meant that the FBH didn't accept the command so possibly the same thing, the ABS ECU hasn't accepted the command you sent it. Current: RR L322 2010
We’ve got to the bottom of this. The EPB must be off before selecting the Maintenance/ service option on the IID Tool. Then it’s all fine and dandy. |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
So what is E7 in relation to testing the FBH then? That’s what I’m currently trying to do. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Following e7 for fbh I get the same with fault codes Flame out. And. Circulating fan electrical fault
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
Seen a few people here refer to IID tool. Isn't it an expensive tool ? |
@jackcramer
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3211 ![]() ![]() ![]() |
£180 + vat here in bristol |
Not sure if I can fix things as it is a complex vehicle. Most I can do is a service and brake change. |
So a off the shelf OBD scanner won't do? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7981 ![]() ![]() ![]() |
AFAIK a scanner will read fault codes.
