Home > General > After purchasing used - first things to check?
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
In case you haven’t seen my millions of posts, I’ve just picked up my 2012 L322 TDV8. Having just learnt (luckily not the hard way) that the oem scissor jacks are a death trap, it got me thinking. What other things should you do, buy or check when you first bring one home? Mines done over 100k miles so a gearbox oil change is near the top of my to do list.
Anything else? I’d prefer not too learn the hard way so any advice really welcomed Smile
Post #534443 16th Nov 2019 11:03am
GGDR
First of all we need pics!
Thumbs Up Thumbs Up Cheers, Greg
Post #534444 16th Nov 2019 11:05am
Fox889
Speaking of gearbox's, perhaps look at a 'mega flush' rather than an oil & filter change?
Some say yes some say no. The Indy I use reckons an ordinary oil & filter gearbox change only gets 60% +/- of the oil out, whereas a mega flush gets the whole lot.
2nd turbo drain mod
oil cooler oil leak
both these on the forum in various places
There will be other recommendations from others who have far more experience than I.
But, most importantly & must never ever be missed is to.................enjoy wafting in total luxury Laughing 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #534445 16th Nov 2019 11:08am
Baltic Blue
I have just put up a post for a bargain Sprinter jack.
Worth you trying to get one, because they are brilliant for lifting L322’s, wheel changing etc.
Post #534446 16th Nov 2019 11:09am
DrRob
Megaflush gearbox. Bodsy is your man. Mobile out of Telford.
Text him on 07770 638023
Top man Thumbs Up
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534459 16th Nov 2019 2:08pm
ur20v
A Trap
Check credit rating and savings.. although you probably should have done this before purchasing a ff.
Next take up that bed in the nearest mental hospital
Really, just drive for a bit, get used to it... problems and improvements will come to light then service the hell out of it to set a good known level of service.
Post #534462 16th Nov 2019 2:24pm
GGDR
Treat yourself:
https://www.fullfatrr.com/forum/topic45845.html?highlight=maglite
It's the little things Thumbs Up Cheers, Greg
Post #534463 16th Nov 2019 2:37pm
M@r]{
Thanks all. I did have the oil drain mod on my radar but mine doesn’t smoke at all, so maybe already been done
Rob, I’ve text that guy, appreciate that thank you
Post #534466 16th Nov 2019 2:41pm
Discotigger
Have the 4 boost hoses been upgraded to the silicon hoses? Easy to check, just lift off the engine cover and look at the 'donut' on top of the engine. The 4 small length hoses are easy to spot, the originals split and give you the 'restricted performance' error. If not done, it's a simple and cheap fix, but will improve your car's performance and your peace of mind. Done mine and what a difference!! Thumbs Up
Check the thread on 'Restricted Performance' on this forum Bow down , it'll give you all the information you need. Thumbs Up
Post #534470 16th Nov 2019 3:41pm
DrRob
Everything I’ve done is on here:
https://www.fullfatrr.com/forum/topic44115-75.html
All quite modest until new turbo Whistle Rolling with laughter
0% balance transfer card Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534492 16th Nov 2019 7:16pm
Discotigger
One other thing to check......swollen nuts!! Shocked Shocked
Talking about the wheel nuts, just replaced mine on a 2012 Westminster, some of them were in a shocking state. Got a good set of stainless alloy replacements and they look so much better than the JLR standard ones that were on. Some of the wheel nuts were so bad that I had to hammer a 22mm Impact Socket on to the nut and use some serious brute force to get them off. New nuts look so much better as well. Thumbs Up
Post #534607 17th Nov 2019 6:20pm
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
Good tip on the wheel nuts, where did you get your replacements from?
Thanks
Post #534609 17th Nov 2019 6:24pm
DrRob
Swollen nuts on my list Shocked Laughing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534613 17th Nov 2019 6:37pm
Discotigger
Got a good quality set from fleabay, just make sure they are the right type and size for your model. Thumbs Up
Post #534614 17th Nov 2019 6:42pm
M@r]{
Got a link for some recommended nuts? Mine were bad, some I had to use a 23mm socket! Also hard to get off!
Post #534616 17th Nov 2019 6:52pm
