Home > Technical (L322) > Battery voltages |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
welcome to the forum..
15th Nov 2019 11:40am |
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 40 |
Thanks Stan, totally agree! My only concern is the 14.8v being on the high side or is this normal? I don't want to replace the battery so that the alternator can take it out???? |
15th Nov 2019 11:48am |
i assume you have an AGM battery so 14.8volts is the max it will take whilst charging... ... - .- -.
15th Nov 2019 11:55am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
https://www.fullfatrr.com/forum/topic43662...eplacement
15th Nov 2019 11:57am |
I should have added....
15th Nov 2019 12:00pm |
Thanks guys, just been reading up on AGM(Absorbent Glass Mat) batteries! AGM is mentioned below the battery part number BH42-10655-BA. Couple of things, what is the BCU, where can I find it and how do you reset it? Is the charging voltage not regulated by the alternator, how would the alternator know you have an AGM battery? Is there anything you need to watch out for when changing the battery? I seem to remember my previous RR from 2003, you had to rotate the steering wheel from lock to lock to release the suspension or something like that? |
15th Nov 2019 12:43pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I think you'll find the BCU is in the way of removing your battery. It is on the front of the battery box, secured by a couple of screws and a cable or two with connectors.
15th Nov 2019 1:11pm |
Depending on which section of the workshop manual you read...
15th Nov 2019 5:44pm |
