Home > Technical (L405) > Suspension Fault: “Pressure does not decrease when..”
pherplexed
United States
Got a suspension fault today and the fault code from my Gap IIDtool reads:
Quote:
“Pressure does not decrease when venting gallery - Algorithm based failure - signal probability failure”
Anybody have some insights on this?
 2021 P525 | Eiger Gray
Post #533852 11th Nov 2019 11:21pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
this seems to be a problem with the l405... check the air drier which is part of the compressor. As the code says it's trying to vent air but the pressure is static. My guess is clogged compressor exhaust which passes through the air drier.
Post #533861 12th Nov 2019 2:26am
pherplexed
United States
Thanks brad s1. Once I get access to the compressor, is checking/clearing the air dryer something that’s pretty straightforward and accessible or does it need to be taken apart? 2021 P525 | Eiger Gray
Post #533908 12th Nov 2019 11:39am
brad s1
I do not know... on older vehicles the dryer used to be removable. Also on older vehicles this error had to do more with a clogged compressor exhaust silencer and less to do with the dryer. Someone else mentioned a similar problem recently and I looked up function of the compressor exhaust in the 405 service manual... Apparently the system vents through the dryer. The dryer itself is just a canister filled with media, you may be able to replace it or possibly open and replenish it. Not entirely sure. I cannot easily find a replacement part online but you may want to do a search and see what you come up with. I could also be totally off base on this but on the l322 and I'd suspect the l405 when the compressor exhaust clogs up air leaving the system cannot leave quick enough and you get this fault.
Post #533914 12th Nov 2019 1:00pm
pherplexed
United States
Thanks for the tips. I dug up the manuals for the system on Topix so I could attempt to check out it this weekend...just in time for the fault to disappear. Rolling Eyes
At least I'll be prepared the next time it happens! 2021 P525 | Eiger Gray
Post #534004 12th Nov 2019 9:35pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
If it does have a sintered brass muffler on the exhaust (as per the 322) you can unscrew it and soak it in white vinegar for 24 to 48 hours to clean it - cleans it perfectly (expensive to buy).
Post #534008 12th Nov 2019 9:40pm
