Home > In Car Electronics (L322) > Supply for dashcam
Brian Considine
Supply for dashcam
I've done a search & checked the Wiki & not found anything.
Is there a feed (ignition or permanent) to supply a dashcam near the sunglasses holder please ?
I have a "hard wired" USB unit.
Thanks in advance.
2003 L322 Vogue. 2003 Range Rover Vogue TD6
Post #532881 1st Nov 2019 7:26pm
This is the method that most people use -
https://www.fullfatrr.com/forum/topic23389.html
Would that work ?
Post #532884 1st Nov 2019 7:50pm
Fox889
I've got a '12 plate Westminster & had to [so Direct Line said] have a Tracker fitted, really nice guy came up & fitted the Tracker no problem, spoke to him about dash cams as I'd got one ready to install, he recommended 'hard wiring' the unit in & not piggy-backing from elsewhere. The main live feed [with ignition] is in the o/s/r boot area which means running a wire from the o/s/r to the front, I'm waiting for him to get a day to come over & do it.
Hope this helps [assuming '03 and '12 plate RR's are the same re-wires etc]. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #532964 2nd Nov 2019 3:48pm
Brian Considine
Thanks for your help guys - I'll look at both methods. 2003 Range Rover Vogue TD6
Post #533206 5th Nov 2019 10:09am
Bill
If anyone from Range Rover reads this, why not have a power supply socket available on /near the dash for all the gadgets? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #533307 6th Nov 2019 1:22pm
Dano0404
On all of my cars I have taken the supply from the interior light. Never had an issue and on the l322 it powers down after a while, also its easy the main reason. 2007 sc
Post #533347 6th Nov 2019 7:13pm
Andy
It’d be great if there was a usb socket on the rear view mirror cowling. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536178 2nd Dec 2019 7:19pm
kooky_guy
I just piggy backed mine off something ignition controlled in the glove box fuse box - Can't recall what now. I don't see why that would be a problem.
Running a cable from the rear to the front sounds like a ridiculous idea. 2010 4.4 TDV8 Vogue SE
Post #536224 3rd Dec 2019 8:55am
