![]() | Home > In Car Electronics (L322) > Supply for dashcam |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
This is the method that most people use -
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
I've got a '12 plate Westminster & had to [so Direct Line said] have a Tracker fitted, really nice guy came up & fitted the Tracker no problem, spoke to him about dash cams as I'd got one ready to install, he recommended 'hard wiring' the unit in & not piggy-backing from elsewhere. The main live feed [with ignition] is in the o/s/r boot area which means running a wire from the o/s/r to the front, I'm waiting for him to get a day to come over & do it.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Thanks for your help guys - I'll look at both methods. 2003 Range Rover Vogue TD6 |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1247 ![]() ![]() |
If anyone from Range Rover reads this, why not have a power supply socket available on /near the dash for all the gadgets? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Dano0404 Member Since: 28 Dec 2017 Location: Uk Posts: 44 ![]() ![]() |
On all of my cars I have taken the supply from the interior light. Never had an issue and on the l322 it powers down after a while, also its easy the main reason. 2007 sc |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
It’d be great if there was a usb socket on the rear view mirror cowling. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I just piggy backed mine off something ignition controlled in the glove box fuse box - Can't recall what now. I don't see why that would be a problem.
