Home > General > Buying: 100k+ miles versus paying more for lower miles |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
On the GAP IID, there's the full manual in the Wiki at the top of the page. Seems complex, but then gels and the service follow up from Patrick and the team there is brilliant.
5th Nov 2019 6:58pm |
If the badges are correct, the first one is an Autobiography Black.....are the wheels factory? And it has the design kit on it..... depends if you like that.
5th Nov 2019 7:37pm |
Need to ensure it’s a real Autobiography Black if that’s something that’s important to you?
5th Nov 2019 7:47pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
The first one has been on AT for quite a while now, so you might get some traction for a deal Got - 2017 SDV8 Autobiography in Loire Blue
5th Nov 2019 7:48pm |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 |
I’m not sure it is a Black....
5th Nov 2019 9:00pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Before you go to buy a Rangie, do as much research as possible as to faults, problems and what to look out for in the running costs department.
5th Nov 2019 9:10pm |
Is it worth paying for a professional and independent pre purchase inspection? If so any around Manchester worth using? |
5th Nov 2019 9:16pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
That first one is not an AB black for sure.
5th Nov 2019 9:18pm |
Definitely won't do any harm, if you're with the AA or RAC you can get an inspection done by them (think you may be able to do that even if you're not a member, but don't quote me!). One thing I would stress is to check over the engine bay with a fine tooth comb. Lift the engine cover and check underneath for oil leaks / soot / gunk around the boost hoses. Look at the threads on this forum about 'Restricted Performance' on the 4.4 TDV8 engines, that will give you a good mechanical idea of potential pitfalls. I'm sure if you ask nicely and offer some beer tokens, there will be forum members from around Manchester who could accompany you when you view the cars and offer their advice, etc. |
5th Nov 2019 9:37pm |
The bumpers etc are just the AB design pack bumpers aren’t they? Factory fit zero cost option? Same with the grills and wheels? |
5th Nov 2019 9:43pm |
I would be somewhat wary of the second car, the one from The Vogue Centre. Check out its MOT History on MOT Check Gov website, its MOT ran out in December 2018! |
5th Nov 2019 9:56pm |
They could be, as i said im not sure, I never saw a car with them bumpers / exhaust on when I was looking. You would need to determine that before buying. If your happy that's what matters Too many toys, not enough time 2011 4.4 TDV8 AB Black |
5th Nov 2019 11:40pm |
FFRRWannabe Member Since: 19 May 2019 Location: Snohomish WA Posts: 39 |
As has already it is about condition and service history. As I recently putchased a 2o11 AB with ~123K, I did it because most all of the major issues were attended to already. The bulk of the bigger issues tend to occur between 80 and 120K so I felt it was worth the price I paid. Also, I personally prefer the 2012 with grill and tail pipe touches, I think they look better. 2011 Range Rover Autobiography
6th Nov 2019 5:11am |
Thanks again all
6th Nov 2019 6:35am |
