![]() | Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 ![]() ![]() ![]() |
I'm only a DIY'er (been one for nearly 60 years) although I didn't have any desire to tackle this job myself, perhaps partly because I generally work alone. However I also wanted insurance cover for the job in case metal shavings found their way into the sump. The 3.0 TDV6 task was simple and although I took nearly double the LR estimated time, it was only an afternoon's job.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Greg,
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 20 ![]() ![]() ![]() |
Looks like I need the oil drain mod, I’m well out of warranty so looks like I’ll be forking out to get this done.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
James. Who did the turbo drain mod for you? Thanks, Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 ![]() ![]() ![]() |
Thought I'd look under the n/s wheel looking just over the shaft to see if I had the mod already done........inspection light, mirror, could I find it, could I heck! I tried looking in front of the n/s wheel then behind the n/s wheel. There are two shiny LR pipes running together parallel but I'm guessing these are a/c, I don't seem to locate the longitude pipes......any clues for a dimwit? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
You really need to get underneath. It's not easy at all though even from underneath.
If you're turbo has been diagnosed as "leaking" and you don't have the turbo drain mod then there is a train of thought going around to have the mod done first (~£1K) and see if that alleviates any oil leaks. Lot cheaper than forking out for a new turbo (£1.8K) plus fitting...
Pictures on this thread might help https://www.fullfatrr.com/forum/topic48944-30.html Need to look behind the 2 horizontal AC pipes to see if it’s been done. Not easy by all accounts ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
I’m looking at buying one with over 100k Miles, with that mileage would it be a safe bet this would’ve already been done? |
Not necessarily Cheers, Greg
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
And they may not suffer from the problem either.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3854 ![]() ![]() ![]() |
Mine doesn't seem to smoke at all, I don't know if the mod has been done but I make sure to "paddle down" a few gears on a long drive periodically to get the revs up to 3k or so. Geoff |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
I’m not in the UK at present and wonder if there is a way to check if the mod has been completed on a car I am interested in. I have the VIN and registration, so how would I go about checking?
Based on what I've read it is a bit tricky to check without getting underneath the car, and then it's not that easy! I'm in the market for a car, I've pretty much resigned myself to taking the car for a steady drive, then after a good 15mins of steady (under 2500rpm) driving, put my foot down and take it above 2500 rpm and keep an eye in the rear view mirror for a smole screen |
