Home > Technical (L322) > New to 322 |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Welcome and hope you enjoy the FF and forum.
3rd Nov 2019 3:46pm |
John-suusex Member Since: 31 Oct 2019 Location: Sussex Posts: 42 |
thanks, i'll wait till a drier day and have a poke around, I think it's towards the front of the engine and might be a rad leak at a certain temp as you can smell coolant in the fan wash after a run..Just can't believe how difficult it is to see anything after the other Rover's! |
3rd Nov 2019 3:56pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Perhaps take it to someone like John Bowden at Gumtree 4x4 for a look see...? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Nov 2019 4:19pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
Thermostat housing is a common cause of coolant leaks on these. It sits between the cylinder banks at the front of the engine. The leaking coolant sits in the V and the water evaporates leaving a red residue that can be seen from above using a torch with the engine cover removed. Worth a check. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
3rd Nov 2019 6:26pm |
thankyou, I'll have a look at the weekend.. 2008 TDv8 Vogue in Java black x2 2000 P38 They aren't all bad! 1996 D1 3.9 es 1996 Volvo 850 GLT |
3rd Nov 2019 6:41pm |
thankyou will look 2008 TDv8 Vogue in Java black x2 2000 P38 They aren't all bad! 1996 D1 3.9 es 1996 Volvo 850 GLT |
Great flat Battery today! 2008 TDv8 Vogue in Java black x2
4th Nov 2019 5:43pm |
