Home > Technical (L322) > New to 322
John-suusex
New to 322
Hi, New to the 322, though have a classic LSE and P38 so know Landrover..lol
Anyway 08 3.6 TDV8 loosing a small amount of coolant now and again. Can't see anything, however there is a faint small of anti freeze every so often.
Cant see anything, but not much room to see, but are there any common problems to look for? It does have rear heating as well.
TIA
Post #533050 3rd Nov 2019 3:29pm
rjff
Welcome and hope you enjoy the FF and forum.
ISTR there are a few threads on this about if you search (try coolant leak). Could be a number of things such as pipes in the engine bay or gaskets in obscure areas. One that springs to mind is something regarding the pipes feeding the rear heater, I think ( await flames Confused if I'm wrong). Can corrode behind the under body shields I think and thus difficult to see.
sorry Stan, should this be in maintenance and mods?? Cheers
Richard
Gap IIDBT
Post #533053 3rd Nov 2019 3:46pm
John-suusex
Re: New to 322
thanks, i'll wait till a drier day and have a poke around, I think it's towards the front of the engine and might be a rad leak at a certain temp as you can smell coolant in the fan wash after a run..Just can't believe how difficult it is to see anything after the other Rover's!
Post #533054 3rd Nov 2019 3:56pm
DrRob
Perhaps take it to someone like John Bowden at Gumtree 4x4 for a look see...? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #533056 3rd Nov 2019 4:19pm
Nick591
Thermostat housing is a common cause of coolant leaks on these. It sits between the cylinder banks at the front of the engine. The leaking coolant sits in the V and the water evaporates leaving a red residue that can be seen from above using a torch with the engine cover removed. Worth a check. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #533062 3rd Nov 2019 6:26pm
John-suusex
thankyou, I'll have a look at the weekend.. 2008 TDv8 Vogue in Java black x2
2006 4.4 Vogue se
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #533063 3rd Nov 2019 6:41pm
John-suusex
thankyou will look 2008 TDv8 Vogue in Java black x2
2006 4.4 Vogue se
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #533064 3rd Nov 2019 6:41pm
John-suusex
Great flat Battery today! 2008 TDv8 Vogue in Java black x2
2006 4.4 Vogue se
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #533158 4th Nov 2019 5:43pm
