Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Greg - perhaps you could offer your DPF clearing service with your new box of tricks Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
15th Oct 2019 3:01pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3144 |
@Greg,
15th Oct 2019 3:20pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Hi Dolphin have you got any message on dash?
15th Oct 2019 3:24pm |
nothing. No faults or signs on the dash at all. |
15th Oct 2019 3:27pm |
Actually at 26g you are a knat's away from a RED:
15th Oct 2019 3:30pm |
Right,
15th Oct 2019 4:54pm |
Lucky break.
15th Oct 2019 5:43pm |
This is a null / not populated value Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 15th Oct 2019 8:54pm. Edited 1 time in total |
15th Oct 2019 5:54pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
My iid is the same version as Greg’s.
15th Oct 2019 8:18pm |
Just to add Dolphin, setting up the screen like mine so you can see those temps is essential, seeing above 600 is the only way to know it's actually happening.
15th Oct 2019 9:16pm |
BTW Your DTC code just means your DPF was saying it was full.
15th Oct 2019 9:18pm |
The field I have on my IID (and some others) is "Diesel particulate filter soot concentration - inferred using differential pressure". It appears that recent IIDs have this instead of an earlier field that was "Non Continuous Soot Mass" - as per Greg's screenshot above.
16th Oct 2019 6:27am |
That's right DrRob, newer IIDs (or if you carry out the software update) have revised fields. I've not updated mine.
16th Oct 2019 6:49am |
Rob,
16th Oct 2019 1:19pm |
